NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Thu Dec 31, 2009 9:33 am
I have 2 maximas and it seems like the emmissions equipment is theproblem when there are these types of issues. It would be bestto consult Chiltons or the floor shop manual before doing the following;
1) Clean your throttle body carefully-I think there is a writeup underthe tech pages too2) Clean your idle air control valve. Mine would spec ok with the multimeterbut was not functioning properly because of carbon.3) Check to make sure your egr valve is functioning properly. Plenty of room for carbon to mess up something here4) Check the coils to see if they spec ok on the multimeter. When attachedto the plugs, you should see a good spark5) Make sure the battery cables are tight and the battery is charged.
Dont lean on the carb cleaner without being very precise as the electronicsensons can be damaged. It try to use CRC electronic cleaner or rubbingalcohol on most parts (not the MAF) with a rag.
If the car has not been maintained very well, then you might consider having the upper intake plenum "dipped" to remove the carbon as well.Just be sure to remove electronic items first.
Some people say dont change to synthetic oil if you have been runningconventional oil but I did it with my car with no problems. If you do this,you might want to change the oil again after 1000 miles to make sure theoil filter is not stopped up.
Sounds like you have a pretty good car that just needs some TLC
