maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Tue Dec 21, 2004 6:22 pm
I'm not sure if the set up on the 4th gen is similar to the 5th gen or not (and not sure of your code)...but on the 4th gen, there is an idle air control valve (IAC) that is near the opening of the throttle body that aids in metering the air/fuel mixture. On some vehicles, if this becomes "gummed up" it can manifest in a stalling problem, especially if you don't clean the throttle body on a regular basis. I would recommend using a good quality throttle body cleaner (sprayed directly into the throttle body) and adding a can of BG 44K to the gas tank. See if that helps...the most you're out is $40. Just my opinion, I'm sure others will chime in as well. Good luck.
