Hello, I own a 2000 Maxima SE with 94k on it.Background replaced the starter at 87k & Napa air filter 89k. Soon after this my Service Engine light has came on. My repair shop has replaced the Knock sensor. Put some miles on the car & light came back on again with crank position sensor code, this was replaced. Shop said to run better gas in the car. I did, but light is on again with P1320 code. same as before.The SEL only comes on only at a cold start & also my Traction Control comes on with the slip indicator light. When this is on the TCS does not work. But when I shut the car off & it's warmed up & restart it the the TCS is off. But the SEL is on.
What I have read I need all 6 ignition coils. I think ???
To install the coils, I should put the Permatex Dielectric grease on the inside plug boot & on the ceramic part of the plug. What about the top part of the spark plug ??Also should I put any Dielectric grease on the spark plug socket that connects to each of the coils ?
Were should I buy the coil packs ?? I seen a supplier on ebay call FCP Groton they have them for 55 each made by Hitachi & also another ebayer called golf6daysaweek that has factory Nissan parts for $ 49
Any feed back would be appreciated. Thanks
Thanks
Modified by CTMaxima at 6:26 PM 1/19/2009
