2000 Maxima Mass Airflow Replacement
artikat10
I am wondering how tough it is to replace my mass air flow sensor on my 2000 Maxima. I am a shade tree mechanic at best however it doesnt look too hard. I had a mechanic clean it a year ago which worked well, but the problem is occuring again. I do use a k&n oiled filter which i am reading is a bad idea on this car. Any tips to help change this thing out would be GREAT Thanks artikat1
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO!
The MAF is very easy to replace. Just undo the electrical connector to the MAF. Unbolt the MAF from the air intake (clamp on one side, 4 bolts on the other). And install the new MAF.
My recommendation would be to remove the MAF and clean it with electrical contact cleaner. See if that doesn't help. K&N filters are easy to over oil.
artikat10
scott, thanks for the advice, I was a little nervous to mess with it, but it looks pretty easy just as you described it...artikat10
lightsout
Car: 00 Nismo Maxima SE
WELCOME TO NICO!!
most of us here on NICO are shade tree mechanics, the best way to learn is to ask questions here...thats what i learned my first week after being a NICO member, and i've got great advice from everyone!!
keep up the great work, and keep on building!!
Devin
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
just a thought, it might not be the MAF. i should make an article about this. most of the time (on VQ30DE/DE-K) the problem is NOT the MAF. it is actually the connector that is plugged into the MAF. this is especially relevant if you have a SRI, WAI, or CAI. the difference in motion causes the red wire to become loose over time, thus allowing a bad connection. check into that, if it's loose, solder it back to get a better connection. i did this 1.5 years ago after going through 4 MAFs. I have had no trouble out of it since. once i found the real problem, i felt like poo. find out what's up and let us know.
artikat10
jltibbs).... Thanks for the good advice. i will be sure to check wiring issues also...artikat1
