Postby
krsdal »
https://forums.nicoclub.com/krsdal-u39008.htmlWed Sep 30, 2009 6:51 am
Can someone puhleeese tell me if the top hat on the rear strut has a reference point? I know the bottom of the rear strut does but do I need to make sure the top hat on the rear struts are located at a clock position? I know the fronts have an OUT reference.
Postby
krsdal »
https://forums.nicoclub.com/krsdal-u39008.htmlThu Oct 01, 2009 11:55 am
Thanks. I'm doing a shade tree strut upgrade. Would you happen to know where I can find the torque specs for the top hat and side bolts to the rear struts on a 2000 GLE??
Postby
Markc »
https://forums.nicoclub.com/markc-u137778.htmlThu Oct 01, 2009 12:08 pm
Don't know about yours specifically. The specs for mine are: tophat- 18-25 ft. lbs. Strut rod nut- 15-18 ft. lbs. Side, (bottom), mount bolt 80-94 ft. lbs.
Postby
MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.htmlThu Oct 01, 2009 3:27 pm
krsdal wrote:Thanks. I'm doing a shade tree strut upgrade. Would you happen to know where I can find the torque specs for the top hat and side bolts to the rear struts on a 2000 GLE??
