2000 maxima coolant loss
venturiguy
Car: 2000 maxima
replace radiator and thermostat still losing antifreeze no smoke nothing on ground what should i look for next
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Try doing a coolant pressure test. Look in the service manual and see what your system normally operates at pressure wise (PSI), then have the shop do the test. Or you can buy or borrow the tool and do it yourself and save some money if you know what your doing. But this will help you find the leak if there is one.
Have you done any maintce to the cooling system?
Nicoclub.com/FSM
