2000 Maxima auto shifting issues
johnnsusie
Car: 2000 Nissan Maxima GLE
My 2000 maxima GLE, auto, 79k, replaced ECM, revs high with no power while shifting from 1st to 2nd gear at slow speeds. I have to either let up on the gas for it to shift or it needs to reach about 3500 rpm before it shifts, usually takes a second or two to shift.
Any suggestions on what it could be?
lightsout
Car: 00 Nismo Maxima SE
transmission fluid level?when was the transmission filter last changed?
ABNRML4U
Car: Nissan B13
I had a 1990 Max and did almost the same thing took it to a Nissan Mechanic and took the transmission out and replaced the gears It had 102.000 miles on the car.
mrL
IACV might need replacing...
lightsout
iacv = Intake Air Control Valve, basically your throttle body bottom end with sensor
lightsout
reset your ECU by taking out the battery for 15 minutes, reinstall it, start it, then let it idle for 11 minutes so you ECU can relearn. take it for a drive around the neighborhood following the speed limit, and accelerate normally. then take it to an open road and to a few stop-start tests by putting the pedal to the floor, this will allow your ECU to relearn your shift points....then repost and let us know what happened
johnnsusie
This worked for about 90% of the problem. Still does it and almost always in the same location on certain streets. Usually when going slightly downhill while car is rolling then giving it gas. But it is much better.
Any other suggestionsThanks
cocotazo
Car: 2000 maxima
Hello did you ever resolve the problem?
