jackofalltrades1980 »
https://forums.nicoclub.com/jackofalltrades1980-u255255.html
Mon Aug 17, 2015 6:19 pm
The AC system on my Maxima doesn't work. When the climate control is switched to the maximum settings (temp dial set to 65 degrees, fan on max) nothing happens, the clutch doesnt cycle on. Thought it needed R134 but system wouldn't take any in after a short burst. Even when I cycled the clutch on manually through the relay, instead of the system working, it popped the valve on the high side like a pressure relief. After doing some research I ended up changing the accumulator and the expansion valve, pulled vacuum and attempted to recharge with the same results, the thing will take a little from the can on the low side and that's it. The compressor won't cycle on, no more 134 moves through the system. If I cycle the compressor on, it'll be the same thing, it won't suck any more 134 in and will pop that pressure relief on the high side after a short while. Also the condenser and the line will be pretty hot all the while. Now if I leave the compressor on and let the pressure balance out to where the thing doesn't pop the high side valve, I'll get some cool air, not blowing snowballs out the vents but some cool air. I then have to drive the car around to get airflow through the condenser to dissipate the heat in order for the slightly cool air to continue to flow otherwise that will stop because the heat isn't being dissipated from the condenser. Since the computer doesn't know the AC system has been cycled on, it won't cycle on the cooling fans until the engine temp goes up to the point that calls for the fans, which surprisingly isn't that often. The main kicker here with this problem is on the climate control display, if I hit the AMB button, it displays -22 degrees. I changed the AMB sensor with two different sensors from the junkyard and still get the same reading. I don't know if the computer is intentionally keeping the AC off because it thinks its subzero outside or if there's some other issue going on. There's really not much else I can think of trying on this system and its ticking me off big time.
