2000 Infiniti G20 Dies while driving.
assclown72
Car: 2000 Infiniti G20
I have a 2000 Infinity G20 that has recently started stalling while driving down the road, there are no codes and it will start right back up if put in neutral while still rolling or by coming to a complete stop and placing in park and restarting. There is no rhyme or reason for when it happens it is just out of the blue day or night. Sometimes you can drive it a couple days with no problem others it will happen a couple times a day. Any help or suggestions would be greatly appreciated. Thanks.
Mr. Callaway
Car: 2011 Nissan Rogue SV AWD
Just experienced a similar issue with my son's 2000 Sentra 2.0.
I took the throttle body off the car. Cleaned the throttle body and the idle air control valve.
Runs OK now and doesn't stall.
Good luck
rob
keepitsimplestupid
Car: 91 240sx
Check you're fuse labeled "electronics" i bet it blown?
assclown72
I have cleaned the throttle body and IACV with no change, Also cleaned the MAF and checked for vacuum leaks. I replaced the crankshaft position sensor and still have the same issue. The car was also at a local garage for a month (reason i haven't re-posted for awhile) and they replaced the distributor cap and rotor, but could not find a problem that is causing it to die. I did find a short in the wiring going into the distributor wiring harness and isolated it and repaired. Rpm will dip and fluctuate than run smooth for a min then just stalls out. Going to take it in to check codes again, i think the dummy light is out. Thanks again for any suggestions.
