maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Wed Jun 21, 2006 3:06 pm
It sounds like something with your overdrive control switch. The bad thing is that with the problem being intermittent, it's nearly impossible to diagnose.
To test, you can check the voltage on the transmission control module between terminal 22 and ground. Make sure the ignition is on, but that the car is not running. With the OD switch on, you should have approximately 12 volts. With the OD switch off, you should get 1 volt or less.
Here's the terminal layout of the TCM.
