ivantechpower wrote:I'm having the same problem,did almost the same as you, waiting on the MAF from e-bay. Can you explain were to get the software and how to clear ecm and adjust the IAVL?
I believe that if you leave the battery disconnected overnight, this will clear the ECM learning, someone correct me if I'm wrong.
Otherwise, you can get NDIS II software & USB/OBDII cable from blazt.biz and it's a little pricey, but it also lets you read and clear codes, display performance data and gauges. I am not affiliated with them.
EDIT:>> I noticed you have a 97 i30, I am not sure if the NDIS II software will work for you, or if you need the first version (which may not have ECM clearing and IAVL learning)
As for having the ECM relearn the IAVL, that may not be necessary if you've never removed the throttle body, again please correct me if I'm wrong. (I don't believe replacing the MAF would necessitate this)
If you want to have the ECM learn the IAVL, there is a method in the Factory Service Manual that doesn't require a scantool.
Well, on to my continued experience.
After a couple of days, the car was not pinging at all from replacing the MAF sensor. Now, after about 150 miles, there was just the slightest, tiniest amount of pinging, mostly heard while accelerating hard, as soon as the car shifted each gear (auto transmission).
I've grown very sensitive to this sound, and it is probably nothing, but I did some more investigating.
I decided to check the condition of the plugs, and found that they
a) had red crud deposits on them. This is due to MMT fouling from all the NOS Octane Booster I've used over the last 12 months.
b) the center electrodes had some spiky deposits
After driving with pinging for a year, using NOS Octane Booster with a very high level of MMT fouled the plugs and creating hotspots for pinging. (this particular booster can raise Octane 60 points but can foul the plugs and injectors, so when you stop using it, the pinging actually gets worse than before!).
I cleaned the red deposits off the plugs, and the little carbon spikes off the center electrode with a small brush, reinstalled, and that microscopic amount of ping went away. I'm going to change the plugs just to be safe next weekend.
Why did a little bit of pinging come back after no ping for 150 miles after changing the MAF sensor?
I would guess that after the ECM was cleared, and did its learning thing over 150 miles, it gets to the point where it adjusts all of its ratios to optimum settings. Engines run most efficiently at just before the point of pinging, and that's how engineers program the ECM, to just go up to that point. However, with the fouled plugs, it started to ping just a tiny bit - most people would not even notice it.
So I recommend you change your plugs too after you get your MAF, cheap peace of mind. Make sure you use NGK platinum -
