Now I don't want to just go and waste money replacing the bank2 cat and sensors (but will do it since they are all up there in age and miles, so might as well do it if they are the real culprits).
So I want to see if anyone familiar with reading o2 data sensor scans can explain what is going on in the scan picture I have below.
After keeping the RPM elevated at about 2,000, I dropped the engine back down to idle.
From the way I understand it:
Bank 1 shows sensor 1 going back into it's normal fluctuation as the ECU tries to keep the bank 1 side of the engine as close to 14.7 A/F ratio as possible.
Bank 1 sensor show the oxygen level at a fairly steady (compared to sensor 1) level after the bank 1 catalyst has done it's job.
(Seems fairly normal to me)
Bank 2 shows sensor 1 going back into it's normal fluctuation as the ECU tries to keep the bank 2 side of the engine as close to 14.7 A/F ratio as possible.
However, sensor 2 goes into "following" sensor 1 fluctuation, but then goes back to showing an almost even rate, but still dipping a lot more than Bank 1/Sensor2
a) why does sensor 2 start fluctuating suddenly?
b) then it stops flucuating as bad, but why is it still not as "steady"
Also, Bank 2/Sensor 1's high peaks seem a lot more "rounded" compared to Bank 1/Sensor 1's peaks.
c) What does this indicate, if anything at all?
Up until the car is warmed up past 90%, it may very infrequently stumble very slightly. I haven't caught this RPM stumble on a datascan (there's no RPM dip in this scan)
Until the car is warmed up, the after-cat sensors don't show anything in a datascan anyway.
d)wondering if this stumbling has anything to do with my o2/cat questions.
Very large image here:
