Mister 26 wrote:
It's an I30T. Does this make replacement more difficult?
It's a little more difficult, but not impossible.
Since it's an I30t, it has HID, so the low-beam bulb is in fact a D2R.
If you look behind the headlight you'll see a silver metal thing screwed to the back of the headlight behind the low beam.
Basically, the idea is, you need to unscrew that (it's called an igniter) in order to remove the bulb. Once you have that removed, you'll have to twist off the connector from the igniter that's attached to the base of the bulb. Then you'll have to push a spring clip out of the way (looks just like an unbent paperclip) and then you can pull the bulb out. Reverse the process to put the new one in.
Now, if you can do all this with the headlight in the car, you'll probably save some time and work. Most people can't, so the other option is to do the same, but take the headlight off the car in order to better access that stuff.
To do that, remove the two bolts at the top of the headlight when you have the hood open. Remove the bulbs/wiring you can from the back of the headlight. Then, go under the car, remove the splash shield under that side of the car, look up, above the foglight, and you should see one more bolt holding a small bracket of the headlight to the fender. It goes in horizontally rather than vertically. Remove that, then pull the headlight out from the front of the car. It's clipped in at the bottom so you'll have to give it a tug to make it come loose.
Good luck.
