snj2000 wrote:I had my code read at auto zone, they tell me P0138 is an Oxygen sensor - Bank 1 Sensor 2.
I have previously replaced my starter and ignition coils (to give you an idea of my experience level)
So here are my questions:
1) Is the O2 sensor something I ought to be able to replace myself? - Yes
2) Any tips or tricks? - Spray WD-40 or PB Blaster before sensor removal. An O2 sensor adapter (@ $10 from Amazon) will help.
3) How can I best find/ identify - Where these sensors are located and which is Bank 1 Sensor 2? - Bank 1 is for cylinders 1-3-5 near firewall while Bank 2 is for cylinders 2-4-6 near radiator. Refer to the description below for additional info
4) I read another post that mentions ECM Reprogramming by the dealer? Is that needed after I replace the sensor? Is that different from resetting the code? If needed and is only done by the dealer, do they usually charge for this out of warranty? - No need
5) Should I replace only this one if that is the only code? - Yes
6) AutoZone says I need Rear. Downstream sensor (located after catalytic converter) part 13374 - OEM exact fit which is twice as much as: 15727 ($60 less) - universal. Opinion: - You have to understand that a lot of people don't know the layout of 2000 I30/Maxima exhaust system. You have two Pre-Cats with two O2 sensors each (Front & Rear, a total of 4 O2 sensors )and one Main Cat with no downstream sensor (unlike 98 I30/Maxima or earlier models which have only 3 O2 sensors)
a) how hard it is to adapt the universal - if you understand wiring diagram, have a good stripper and crimper, it should not be a problem. But cutting the wire short and making the wrong crimp-connections may require you to buy another universal sensor. Also, a bad crimp can have poor electrical connection and/or corrosion over time.
b) recommended one over the other? If I were you, I would buy NGK/NTK exact fit. You need P/N: 24574 (HO2S2-B1) and currently is @ $52 at Amazon with free shipping - http://www.amazon.com/s/ref=nb_sb_noss? ... 74&x=0&y=0 . Very hard to beat that price.
I do respect the opinion of 'yang" and hes done great contribution to the forum. But having an O2 extender means cheating the emission system. With the O2 sensor moved away from the exhaust stream, the ECU thinks you're running richer than normal (High voltage) and thus reduces fuel-air ratio resulting in a lean mixture. A lean mixture may save you some gas but will generate more NOx, a pollutant (since there is not enough fuel to consume the Oxygen in the combustion chamber) and result to higher engine temperature. Also, it's possible to fail Smog Check with high level of NOx at the exhaust. I'm from CA so I'm really concerned about pollution.
Here is an info I posted some time ago.
Since owners of earlier I30/I35/Maximas (1999-CA, 2000-CA & Federal and beyond) have started replacing O2 sensors, I think it would help you if I clarify some points about the VQ engine exhaust system and related O2 sensors. Please refer to the diagram posted by "maxhopper" earlier. Unless mechanics know your car, they would inadvertently replace the wrong sensor as what happened to "snookhums."
First, the transverse mounting of the VQ engine places Bank 1 (cylinders 1-3-5) close to the firewall while Bank 2 (cylinders 2-4-6) is close to the radiator. So if you are under the car, the front exhaust pipe is for Bank 2 and merges with Bank1 exhaust pipe downstream of Bank-1 Pre-Cat (This is where some mechanics may get confused).
Front O2 sensor in general is mounted before (upstream) the catalytic converter while the Rear O2 sensor is mounted after (downstream) of the catalytic converter. As applied to VQ engine, FRONT O2 sensor has 3-wire (power, signal and ground) while REAR O2 sensor had 4-wire (power, signal, ground + dedicated signal ground).
On this particular generation of cars, there are 3 catalytic converters - Bank 2 Pre-Cat (in front of engine) mounted vertically, Bank 1 Pre-Cat (below the engine) mounted horizontally and then the main/rear catalytic converter.
As for the O2 sensor location, cable length, original harness color-coding and connector location, see info below:
Bank 1 O2 Sensors
-HO2S1-B1: Front 3-wire sensor with BLACK harness, @ 25" long with sensor mounted on the vertical section of the Bank 1 exhaust pipe with connector mounted on top of the engine, rear pax side
-HO2S2-B1: Rear 4-wire sensor with WHITE harness, @ 38" long with sensor mounted in front of Bank 1 Pre-Cat and connector mounted on the radiator side
Bank 2 O2 Sensors
-HO2S1-B2: Front 3-wire sensor with BLUE harness, @ 11" long with sensor mounted before B2 Pre-Cat (sensor is visible in front of engine) and connector mounted on the radiator side
-HO2S2-B2: Rear 4-wire sensor with RED harness, @ 31" long with sensor mounted downstream of B2 Pre-Cat (horizontal section of the pipe) and connector mounted on the radiator side
For most OEM parts, best pricing is from one of NICO sponsors, IoS (Infiniti of Scottsdale) at "infinitipartsUSA.com a.k.a. "everythinginfiniti.com" also "everything nissan.com. They typically have 25% off MSRP.
For best pricing of OEM and quality replacement O2 sensors and spark plugs, it's very hard to beat NGK.com a.k.a. "sparkplugs.com." This is where I usually buy those particular parts. The "oxygensensors.com" referred to by OP is also reputable and in addition to quality replacement parts, also sells Walker and Universal sensors (requires cutting and splicing of wires). If you are patient enough, you can look at eBay (be wary of cheap sensors) and Amazon.com.
Hope that isn't asking too many questions, any input is appreciated.
