mike312 »
https://forums.nicoclub.com/mike312-u63298.html
Tue Jul 10, 2007 5:37 pm
Bit more info
The car will reverse a bit, but then it grinds to a halt as if something gets caught that prevents it from moving back further. If I put it in park, you can sometimes hear a popping noise from somewhere under the hood, and then the car will move back a little furter. SOmetimes, turning the wheel seemed to cause the popping noise too. Putting the car in Park didn't always work, so I would drive forward a bit, and then reverse a little more. This allowed me to slowly mve the car back
Now, one other thing I noticed is I took off the front left wheel where I heard the original noise. I was missing one of the 2 bolts on the calliper. I could actually pull the lower part of the calliper off of the rotor as it was hanging free. Could this be what is causing the issue?
Driving forward seems to be no problem, as I drove home. There seemed to be some rattle from the front calliper being loose
Thanks
