loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Mar 01, 2010 9:48 pm
You should have posted in the Q45 forum and indicate the model year of your car. Aside from differences in the number of cylinders, some Maximas/I30s have ECM relay whereas there is none in the Y33-Q45. The coil base bias (Pin 3) from the ECM for the I30 is 0.20VDC while for the Y33-Q45 is 0.38VDC with engine at Idle.
Try cleaning the ground points of the main engine harness. In the Y33-Q45, they are mounted on top of the engine, near the oil dipstick. You can also check the ignition coil resistance - a 0 ohm reading across Pins 2 and 3 indicates a bad coil (short circuited base-emitter junction of the transistor inside the coil).
