pepzigdoo59 »
https://forums.nicoclub.com/pepzigdoo59-u66907.html
Thu May 31, 2007 2:28 pm
Car continually pulls to right while driving (at any speed). I have had front end aligned 5 times over last 2 yrs. Every time i get fed up with fighting to keep the car on the road, I take it to a front end man. Which, by the way, leaves me with another new part/expensive bill, not to mention leaving with the same problem I went in with.Took car to Firestone this morn. Reason: 1) Bad wobble when brakes applied. (rotor's turned problem fixed). 2) Tires rotated. 3) A popping or clunking sound that seems to come from the left font end. This has drove me nuts every since i've had the car (2 yrs). No one could ever tell me what it was, or fix it. Well, when they called me with their diagnosis, the said the right cv boot was cracked/leaking grease (on left side half axle). Said they would only replace entire left axle, as the other boot would crack soon. Told them to do it. I figure i'll eventually have the entire front end replaced and maybe the problem will be fixed. I think it actually was the culprit of the CLUNKING! I'm not positive, though. It may be that the car was driving better/quieter due to the EXTENSIVE LIGHTENING OF MY WALLET. I'll know for sure after this week end.So, to date: Multiple line ups (with no results), new lower left control arm, new left wheel bearing.Oh, Firestone also recommended replacing the following(which I declined as i could not afford the total bill, $850, in one wack!) : 1) Both outer tie rod ends (extensive play) 2) Install sway bar link kit 3) Alignment 4) Rear rotorsIf your not asleep by now, any comments/suggestion for pulling to the right would be well received.
