nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Tue Jun 06, 2006 7:44 am
Well it's not exactly a high performance car. It weighs somewhere in the upper 2000lb range and has 145hp, you do the math.
You could get a few hp from a new intake and exhaust system, just like any other car. It'll definitely help the car breath better such to fatten up the midrange power and keep it a little stronger up top too. At that point, you could add a header and even cams if you still don't have what you want. These cars also benefit from a re-grounding, as, for some reason, the grounding sucks. Many people report a significantly smoother power delivery from a regrounding job.
Of course, you could turbo or swap if you wanted to too, the choice is yours. But if you just want a little more grunt, do i/e and see where you're at.
