centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Dec 22, 2017 12:45 pm
Seems like water got somewhere it shouldn't. Or a loose connection was created from being jarred around maybe. I'd check all the stuff on and between the battery and starter. Even remove and reconnect wires and grounds. Then I'd check related fuses and relays under the hood. Seems like the alternator isn't connected properly to me, but I don't know. It should have a fat power wire screwed in, a smaller ground wire screwed to the chassis of the alternator, and a set of wires in a plug for some balancing control electronic stuff.
