RhinoKnots »
https://forums.nicoclub.com/rhinoknots-u291767.html
Wed Aug 21, 2019 8:52 am
HELP... Hello all. First time using this forum and I'm hoping someone can help. My Frontier is just starting to get broke in at 284,000 miles. Have never had any issues other than maintenance items until now. I have been having an ongoing issue with a misfire while driving. It doesn't matter what speed or road condition. The problem has caused my Camshaft Position Sensor to fail about every 1000 to 2000 miles in the past 9 months. Luckily I was able to replace under warranty. Because of the ongoing issue, I have replaced my fuel injectors, fuel pump and fuel regulator. Distr4ubtor cap and rotor are new with distributor. My codes always come P0305 (cylinder 5 misfire detected) then turns into P0340 (Camshaft Position Sensor A). I have switched wire and plug from 5 to 3 and still get misfire code on 5. Is something causing my Camshaft Position Sensor to go out or the warranty rebuilds that bad? WHAT AM I MISSING??? IN SERIOUS NEED OF SOME HELP.
