2000 Frontier 2.4L turns over but won't start.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I am working on a Frontier that won't start. Here is what I have determined so far. The engine has plenty of spark, the fuel pump is working, and fuel is spraying out of the injectors. I didn't have a fuel pressure gauge at the time to test fuel pressure so I pulled the fuel rail up so that I could watch for fuel spray from the injectors as I spun the distributor shaft. They were spraying good. So I figured the pressure must be pretty good for that to happen. The truck will run as long as carb cleaner is sprayed into the throttle body. I was told that the truck was fueled up at a BP gas station just before this happened. I collected some fuel from the fuel line into a glass jar but didn't see anything visually wrong with it.
Is there anything that I need to try that I may have missed?
Thanks,
Matt
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
were plug wires off and the firing order messed up?
Are the plugs wet? (Really easy to check on a KA motor)
check wiring to MAF or TPS
mattd1979
I mentioned that the problem started after he filled up at a BP gas station. The truck was running fine before this. After I got home, I transferred the fuel I collected into a glass jar. The day I collected it, it didn't seem strong like fuel does. The next day however, I opened the jar and it was very strong to the smell like I expect fuel to be. I don't know what the deal is at this point. I am going over there in the morning with another fuel pump that I am going to run directly from an external fuel tank and plumb it to the fuel rail and see if it will run then. If it does then there is obviously something wrong with the fuel in the tank.
mattd1979
It turned out that there indeed was diesel fuel in the tank. I ended up removing the relay and jumpering the fuel pump so that it would empty the tank into 2-1/2 buckets 5 gallons each. I then put in 5 gallons of 87 and all is now good.
Matt
