2000 Anniversary Edition Ride
rover3l
Car: 1998 Q45, 2000Q45 Anniversary, 1965 Rover 3L,
At 95,000 my suspension feels a little worn. Symptoms are general lack of tightness and I think too much noise over larger sharp bumps, pavement joints etc.
I have the anniversary model and so I realize the struts would be expensive. I guess I would like to understand what others have had to pay for a set of these. Also in terms of other parts that could or should be replaced what would people recommend. I am thinking stabilizer bushings, tension road bushings.
Would anyone care to describe how good and how quiet the ride should be on one of these vehicles?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
In Joe we trust
http://www.infinitipartsusa.com
Call them. You will need front strut bearings and 4 gaiters and bump stops.
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
Here is the list of suspension parts you will need (front and rear):
54302-3H926 1 STRUT KIT FT RH 54303-3H926 1 STRUTKIT-FRONTSUS 54320-3H900 2 INSULATOR ASSY-ST 54325-4P001 2 BEARING-STRUT MOU 55031-41L00 2 TUBE-REAR SPRING 55031-6P100 2 TUBE - SPRING 55034-0P000 2 SEAT-RUBBER,REAR 55240-0P000 2 BUMPER ASSY-BOUND 01225-00102 10 NUT SELF LOCK 01225-00231 10 NUT 08912-3401A 10 NUT 08912-6421A 10 NUT 08918-1421A 10 NUT-HEX 54034-4P000 2 SEAT-RUBBER,FRONT 54050-4P702 2 BUMPER ASSY-BOUND 55322-4P701 2 BRACKET ASSY-SHOC 56210-3H925 2 ABSORBER KIT-SHOC
Talk to Joe 1-888-216-5328. He'll give you a good deal.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
also don't forget about the tension bars, that is probably a big part of your problem. you need either new rubber (if you want to pay for the labor) or the entire bar with the rubber already mounted in there.
rover3l
Thanks everyone for the feedback.
This is probably going to be my early summer project so I had better get saving
