2000 Anniversary, 139k miles, stuttering power steering when cold.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Recently (15k ago) did a PS flush along with all other vehicle fluids. For the first time ever today my car malfunctioned since I bought it last year with 72k. It was a heartbreaking shatter of my mispercieved reality: my car is always perfect!
In any event, the power steering stutters when the car is first started and is not moving. I.e. backing out of a parking spot causes some sporadic PS and a screeching belt.
Anyone ever expierienced this on their 130k-ish y33?
I'm starting to feel like my $0 expense car is going to start costing me.
By 2009 I should have over 200k miles, with 130 done in just over 2 years.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Pulleys and belts?
Deferred maintenance will bite you hard when big parts or major systems fail.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
I need to change them anyway. Just did a tensioner pulley on my Durango.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Hows the fluid and everything like that??? If the steering goes out with the belt screech, then check it.. Maybe for giggles tighten the belt a tiny bit.
Q451990
Check the fluid for sure. Low fluid will cause lots of chattering.
Heath
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
Q451990 wrote:Check the fluid for sure. Low fluid will cause lots of chattering.
Heath
Sorry, didn't say-fluid is fine! I gotta change the belts I'll handle it then.
twebster725
Car: 2008 Infiniti FX35 AWD
Did tightening the belts take care of your problem?
My power steering (at least I think it is) started whining recently when the temperature dropped to around freezing, but I don't have any problems steering it. It just whines louder when I turn the wheel. After the car warms up it stops whining. My fluid levels are okay.
My husband stuck is head under the hood, but couldn't tell if it was a belt or something else not related to the power steering.
Any thoughts on what could be causing the whining would be great.
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
I changed all my belts a few weeks ago and the Pwr Steering belt was not quite tight enough. On a cold morning it would screech like mad at first, and then after it shut up, you could still feel the loss of hyd power in the steering wheel. I tightened that mother up and alls well.
Sometimes it's something simple.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
twebster725 wrote:My power steering (at least I think it is) started whining recently when the temperature dropped to around freezing, but I don't have any problems steering it. It just whines louder when I turn the wheel. After the car warms up it stops whining. My fluid levels are okay.
Get a set of belts from Joe and be prepared to replace the 6 bearing assemblies in your pulleys with ones of equal or better quality (no Chinese ones!). Replacing only one or two means you will be back in again soon and after the second time labor will cost more than the replacing all the parts will the first time.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
paranoidjack wrote:Recently (15k ago) did a PS flush along with all other vehicle fluids. For the first time ever today my car malfunctioned since I bought it last year with 72k. It was a heartbreaking shatter of my mispercieved reality: my car is always perfect!
For the record, my car fixed itself and hasn't hiccuped since. 20k miles ago!
fixer
Car: 08 Sentra
the power steering reservior on the y33 is the stupidest design, if the p/s flush was not done properly and a little air was allowed to go into the pump, it will cause a little noise and sporaddic action from steering. the reservior can look full but be bone dry on the suction side. there are two chambers in the reservior. when you fill the reservior, it will go in the outer chamber and will look full. fluid is sucked from the inner chamber and feeds the pump. it takes a few minutes for fluid to transfer from one chamber to the other. if any work is done to power steering and air gets into the pump, it usually takes me 45 minute to completely bleed the system. the system will eventually bleed all the air out but may take several weeks. in the meantime the customer will have to deal with noise and erratic power steering. it sounds like your veh had a little air and took a little while to completely bleed out.
