Awesome info! I to chase vibrations in my 97Q. Ive got Michelins and that by far made the biggest improvement.Q45tech wrote:Of course! Temperature changes in sidewall stiffnesss and tread create [allow] vibrations that vary as the tire warms up and stiffness changes.
Tires are a spring and as long as perfectly round [same stiffness at every point around circumference] and fitted to a perfectly round and in plane wheel [axial and radial runout = zero] the forces are balanced. As the tire rolls on a perfectly flat road there is no change in upward pressure on the metal springs.
When a tire or wheel is not round or doesn't have an equal distrubuted mass [heavy spot].............these locations create a unequal force as the tire rotates so the tire pushes up on the spring with more force OR in and out on the wheel bearing which transfers force to the lower suspension arm.
Shock absorbers are desisned to work at very low frequencies [zero>1-2 Hz] they cannot keep up with 13 Hz [26" tire rotation at 60 mph] same with spring and steering rack.......it/they just pass the vibration thru to body.
Members don't realize that most tires are BAD, they are not perfect when they leave the factory and just get worse for every mile used. Same with wheels, they all bend and become less round. Factory wheels tend to be stronger than aftermarket wheels because they need to last thru the warranty period.......why you never see a warranty on aftermarket wheels, you never even see written roundness/runout specifications.
Michelin uses special expensive materials in their sidewalls that are 1.5-2 times stronger per inch thickness than conventional tires. That and expensive robotics creates a rounder more consistant tire, then QC rejects the failures instead of shipping them........for buyers to sort out.
It is extremely expensive to test every tire.Tires made by humans always have variations because the mold area is very warm [hot working enviroment]...........getting the dougnut off 1/16" in the mold creates a bad tire.
1 in 10 tires made by humans have problems* [1 in 100 have severe problems] as opposed to 1 in 1000 by robots [numbers given to me by Michelin].* depends on YOUR standards of perfection, obviously the tire industry assumes American don't care as long as they don't blow out.
Every tire that gets mounted on a Nissan wheel at the factory gets tested and match mounted..............that doesn't guarantee much after it sits on the boat and get to dealership.
The Hunter 9700 has caused serious financial hardships [they cannot just ship their failures without recourse] for wheel and tire manufacturers, now that accurate testing is available to the masses for low cost.
