2000 ALTIMA transmission BEARINGS
General discussion area for the L30-chassis Altima
JUNIORJEDAT
Car: ALTIMA 2000
BY THE WAY, NEWBIE AT FORUM. DOES ANY ONE KNOWS HOW TO CHANGE THE INSIDE BEARINGS OF THIS TYPE OF MANUAL TRANSM, AND WHAT SPECIAL TOOLS ARE REQUIRED, TALKING ABOUT THE INSIDE OF THE transmission ITSELF NOT THE CLUTCH AND ITS PARTS (P.P, FLY WHEEL, RELEASE BEARING ETC.). PLEASE EXPLAIN FROM A TO Z ON HOW TO DO IT. IF AVAILABLE DIAGRAM. THANK YOU.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Do you have a Factory Service Manual? They are pretty good in explaining the dismantling and assembly process. They also list the special tools needed and provide diagrams.Bud
JUNIORJEDAT
Car: ALTIMA 2000
NEVER THOUGHT ABOUT IT, SINCE I'VE DONE SO MANY REPAIRS ON THE CARBUT NEVER INSIDE THE TRASNMISSION ITSELF, GOOD SUGGESTION I'L TRY TO GET ONE FSM FROM THE DEALER OR FIND ABOUT IT SOMEWHERE ELSE.
Cold_Zero
I would suggest finding it online. The dealer will charge you an arm and a leg. Do a search on NICO, someone on here is hosting all of the Altima FSMs.bud
Return to “2nd Generation Altima Sedan (1998-2001)”
