2000 altima Problems after replacing Converter.. help...
General discussion area for the L30-chassis Altima
Jimmy Vance
Car: 2000 Nissan altima
I had a P0420 code.. so I replaced the converter with a after market one , now i get numerous trouble codes. odometer doesn't read.. interior lights don't work, key fob don't work, it does not idle right and will stall.. check engine light should be on with all these codes but now wont work.. did I make a mistake by not disconnecting the battery prior to replacing the converter... what to do now?.. I disconnected the battery hoping it resets itself.. what could be the problem here?
Reason: Deleted duplicate threads
Jimmy Vance
I believe my unified control unit board is bad..no turn signals wipers no gauges work at all.. My bad.. forgot to disconnect battery cable prior to catalytic converter install, as I had to remove alternator and cooling fans to remove exhaust manifold.. possible i shorted something out somehow? or is there a fuse to look for?
Jimmy Vance
problem solved it was the battery fusible link
Return to “2nd Generation Altima Sedan (1998-2001)”
