stocker2000 »
https://forums.nicoclub.com/stocker2000-u16929.html
Thu Apr 13, 2006 10:44 am
In the past week or two, I noticed that my car had a slight lope/vibration in idle. This morning my Engine light came on.
Brought the car to the dealer for diagnosis. They told me that my "intake" gasket is leaking, and that coolant was seeping into cylinder #4, causing my light to come on and also causing my lope. They said that there is a total of 3 gaskets they need to change.
I'm wondering if this is plausible? If a leaky gasket is causing coolant to get into the cylinder, then do I assume that the intake manifold has coolant running through it?
Also, will my spark plug be fouled, and need to be replaced?
Oh ya, should I get the PCV valve replaced at the same time? It's a pain to access in my car, and if they need to remove the intake manifold anyways, it may worthwhile doing at the same time.
Your opinions are appreciated.
