2000 altima electrical gremblins
General discussion area for the L30-chassis Altima
1calvin
I purchsed the car with 50,000 miles on it and over the past 3years the dash panel has gone dead intermintly maybe 10 times, usaully shut car off and resart it's ok ,one time it would not start tow to dealer reprogram key and computer and car's ok ,and most resently my 19 year old daugher says car sounded very strange and had no power,she pulled over shut it down restart and everythings ok agian, Sounds as though it went into limp mode? Called dealer they say no common problems anybody have suggestions, Dad
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Welcome to NICO.
You signed your name as "Dad" after your post.....so...welcome Dad!
Anyway, what exactly on the dash panel has gone out and what else (if any) along with it at the same time? Is the car stalling at a stop? When you said the car had no power, do you happen to know what RPM's the engine was able to go up to and how many MPH could the car go when you had this problem?
Electrical problems in a car are hard to diagnose sometimes. Hopefully a few of us here can give you some insight. I'm surprised the dealer couldn't help you. Perhaps go to a new mechanic or dealer.
1calvin
the car has never stalled only the speedo and tach go dead I am not sure if water temp or other gauges fuel ect are involved the car continues to run fine, when shut off and restarted dash returns, the strange noise Iam not sure getting info from 19 year old and it only happened once , she said leaving stop light when accelarting car made strange sound as though not running on all 4 and it would not accelarate had foot to floor no power , pulled over shut down resart and problem goes away
Thanks Dad
guitarmn07
Car: Azure Blue Altima Coupe 3.5SE Charcoal PP
This may not help, but I had a van that did that to me... it was the alternator.
SHIFT_COUPE
guitarmn07 wrote:This may not help, but I had a van that did that to me... it was the alternator.
My thoughts exactly. I would have guessed this were an alternator issue but why couldn't his dealer diagnose it is above me.
1calvin
Thanks gentlemen for your help, I looked at alternator and the input/output connnector was not pushed all the way in and clipped , it was more or less floating in the socket sure looks like it could be the problem,
THANKS AGAIN Dad
Return to “2nd Generation Altima Sedan (1998-2001)”
