Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Sun Aug 19, 2007 2:45 pm
As a precaution, try the following diagnostic method. Go to your local autoparts store and buy some Carbuerator cleaner. With the engine running, spray the carb cleaner on the intake manifold where it bolts to the head near cylinder 4 (you are trying to spray on the intake manifold gasket). When spraying it, take note if there is a change in idle. If your idle does change, then your intake manifold gasket is leaking and air is entering the system, which will cause a lean condition, and furthermore, a cylinder mis-fire.
