2000 Altima and NO ANSWERS..........Gurus Please Help
Jus14
Car: 97' S14 and 08 Versa
Ok i got a 2000 altima just replaced the engine and yes its the Vin code D engine that i replaced the old one with ,everything is plugged up no broke wires no where ,new distributor,distributor cap,rotor button,crank position sensor,ecu,plugs,plug wires,and checked and replaced all relays and fuses,any thing im missing cause i just dont know.............
windhaven
Car: 2008 Nissan Altima Coupe 3.5 CVT Winter Frost/Blond Full Load
So, you've just replaced an engine, plugged it in. What exactly is your question?
Are you trying to do a double check before firing it up? Or, have you tried and it didn't start?
-- Wind
Jus14
It has no fire at all i can stick my finger in distributor and nothing......but i know its getting fuel and everything is working but no fire anywhere....
