TylerW »
https://forums.nicoclub.com/tylerw-u140828.html
Sun Apr 03, 2016 6:04 pm
Hey guys:
I sold my previous '98 T and was out of a Q for a year. I found and bought another one a while back, this one a 2000 Anniversary Edition. I like it, but it's not running exactly right.
What's going on is, most of the time the power is off at lower rpm, say under 3K. Essentially, give it some gas at lower speeds and it almost tries to nose over for a couple seconds. Then it'll recover and go on. If you gas it hard, it goes like a banshee. It's just like a carbed engine with a bad accelerator pump.
It doesn't stall. It idles perfectly. It.is.not.misfiring.I had to do both coil packs and plugs on the other car at various times and so I'm very, VERY familiar with misfires on these and it's not doing that. There's no 300 codes and it runs fine under a hard load. It's smooth at cruise speeds.
I noticed if I'm climbing a pretty steep, 45mph mountain near here in 3rd(OD locked out) that I can definitely feel the engine surging lightly. Not a miss, a surge. There's a difference. It also seems worse the hotter the temps out. Occasionally all the low rpm response comes back and it reminds me that it's not well.
The only other thing I suspect is related is that it has a long crank 95% of the time. The other car did that when it heat soaked but this one does it hot OR cold.
Your thoughts are appreciated. Don't say the CP word.
