Anybody??
http://www.flickr.com/photos/raghu_66/4601689467/
http://www.flickr.com/photos/raghu_66/4601689463/
The above is the pic of my dist. rotor. I am being told that the center (axis) of the rotor as marked by the yellow line, is not precisely aligned with the index point, marked by the orange circle, where the spark jumps/carries on to and through the plug wires. And that this has happened because the timing belt has jumped a few teeth and hence the timing is off and hence theres no spark?? Better this than the timing belt breaking.
Does that diagnosis seem correct?
I really need some help here guys. I have no clue how to proceed as I am a novice and learning. Does the misalignment of the rotor got anything to do with timing advance? Or is it cause of incorrect timing due to broken teeth on the belt?
I am wondering if I should start with the cap and rotor or the whole dist. assembly or take it shop to have the timing belt looked at and replaced(?).
Any help would be appreciated.
