200,000 mile mark
Q45Racing
Car: 1991 Q45t w/HICAS STILLEN CAI, JWSTB, CALI CUSTOM, TOKICO
well folk made it to the 200,000 miles mark, car still runs like a champ, also havent spent much in major maint, did all four brakes and had the rotor turned, gonna get 2 new rear tires, might go yoko avs 225-60-15 or 235 for the rear... i changed the brakes and the brake pad light still on, r u sure the factory doesn't reset those... this is like my 3rd time doing these and light stayson..other than that i gotta have one of the cleanest 91 Q around i paint my stock pie wheels every now and then , helps them look like new.. with chrome spray paint.... try it you'll like it...:beerchug :thumbup
Q451990
As far as the brake lights are concerned... they are reset only by replacing the bad sensor. The sensor is nothing more than a wire running through a plastic peice that closes a circuit. As long as the circuit is shorted, the ECU thinks everything is normal. If the pad thickness get's too thin, then it rubs through the sensor and opens the circuit. You should be able to short out the two contacts in the harness going to each sensor to make the dash warning go away. If that doesn't work, you have an opening somewhere else in the circuit that's not normal.
Heath
DAEDALUS
Car: 1990 Infiniti Q45
Two ways to do a quick check. Disconnect the sensor harness and get out your multimeter. With the key turned to ON check for voltage on the ECU-side terminals. Check the sensor-side terminals for continuity. If you have both voltage on one side and continuity on the other, then you'll have no error messages OR your ECU is fried.
