20 X 9.5 inch rims in the front
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
I know there are some guys running 20 or bigger X 9.5 inch rims in the front, what size tire are you running? what is the offset of your rim? I have a set of ADR Classic 20 X 9.5 with a +35 offset and I need to know what size tire to run with that set up. I do not like the stretched tire look at all. Thanks in advance
TOMatBMR
Car: 2006 M45 Sport
I ordered some Niche Milan 20x10 +40mm front and rear for my 2006 through my work. They should be in on Thursday. I will be using my current 245/35/20 tires on them all but will go wider when they wear out because I know it will be a little more stretch then I like but my tires are almost new.
mexillis
Car: M45s
I ran 255/35 on a 9.5+25 there was a member with 20x10+38 with 275 30 all aorund so you could run that if you want width.
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
TOMatBMR wrote:I ordered some Niche Milan 20x10 +40mm front and rear for my 2006 through my work. They should be in on Thursday. I will be using my current 245/35/20 tires on them all but will go wider when they wear out because I know it will be a little more stretch then I like but my tires are almost new.
do you have pics?
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
mexillis wrote:I ran 255/35 on a 9.5+25 there was a member with 20x10+38 with 275 30 all aorund so you could run that if you want width.
did your tire have the stretched look?
Amgberg
Car: 2006 m45 sport blue tint, STR 20x10.5, full Megan exhaust.
2010 E63 ////AMG stock
bicsintegra wrote:I know there are some guys running 20 or bigger X 9.5 inch rims in the front, what size tire are you running? what is the offset of your rim? I have a set of ADR Classic 20 X 9.5 with a +35 offset and I need to know what size tire to run with that set up. I do not like the stretched tire look at all. Thanks in advance
can fit up to 20x10.5 east that's what I have +35 offset all the way around
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
AMGBERG
what size tires are on your car in the picture?
Amgberg
bicsintegra wrote:AMGBERG
20x10.5 +35 245/35 nice strech and a good sidewall for pot holes
Amgberg
tires are stretched because I don't like the look of square side walls. for the y50 I think 20x10.5 +35 all the way around is the perfect wheel fitment for this car. that's why I choose it I don't see the point in staggered setup.
and I drive this car every single day in bad Philadelphia roads
mexillis
Car: M45s
the falkens I ordered are 10" wide so def no stretch for a 9.5 wheel. Even with the 10.5 and same tire/brand I had a slight stretch which is what I like since it was the widest I could go with the GTR wheels and not pull the fenders too much.
mexillis
Car: M45s
this is the only shot of my wheels from an angle that will sort of allow you to see no stretch at all if you look towards the bottom.
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
thanks for the pics and the info.
Wangtang408
Car: 2006 Infiniti M35
You need to slammed cuz it doesn't look right!
TOMatBMR
Car: 2006 M45 Sport
Unfortunately thats the way I am going to be rolling for a few months too until I can get finances straight for suspension mods/upgrades/maintenance.
