20 x 10.5 +45 can fit?
pharaohEG08
Car: Black 08 M35
Anyone know if a 20x10.5 +45 offset will fit on an 08 m35 without rubbing or any body work. I'm on Tein H-techs right now but will have BC coils at time of wheel purchase.
pharaohEG08
Car: Black 08 M35
I should probably mention that the above is for the rear wheels. Fronts are 20 x 8.5 +38
mexillis
Car: M45s
yep those will fit fine with some room. You can either put a 285 or 275 in the back. I would go more aggressive in the front if i were you to match the rears. Maybe a +20 or +25.
pharaohEG08
Car: Black 08 M35
A lower positive offset on the front means a little bit bigger lip correct. Unfortunately the wheels I'm looking at are used so i don't have the luxury of choosing but I will keep that in mind if I look into something else. Gracias señor
