Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Fri Mar 18, 2005 6:22 am
Heh, you guys are pretty funny. The very fact that carbon fiber is conductive means that it will act as a shield to surpress EMI. And I know R/C stuff is glitchy around small sources of EMI, but Nissan and other OEMs don't play around. After all, the ignition system alone puts out more RF than your local radio station! Just kidding, but really, your ECU, MAF, etc. were designed to be used in a very, very noisy and harsh environment.
There is a maxim or proverb... forgot who said it, but it goes something like this: The simplest explanation is usually the correct one. So yeah, check the MAF wiring/shielding, anything bumping the hood, etc.
It is highly unlikely that your MAF, which measures true mass flow regardless of temperature, is affected by the under hood temperature (unless it is through a wiring short). And it is equally unlikely that your cf hood is causing electrical interference.
I also doubt it would have to do with the coolant sensor, since that is used to richen the mixture over the base maps and your problem is leaning out.
