20's on drop coupe will it fit?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
ecuazo
Car: infinity g35 coupe
I have a 05 coupe and i trying to come up with a good suspension rim tire combination i have two options in mind but not sure if it will work either staggered 19"s 8.5 in the front 9.5 on the back and a drop with eibach pro springs kit (can't afford coilovers now)or 20"s staggered 8.5 on the front 10 on the back same springs tire would either be a 275/30 on the back and 245/35 on the front or 245/35 on the back 225on the front any suggestions are welcome and pictures would help stance is very important hate the gap between fenders and tires.
TISon28s
Try to stick with sizes close to factory. Going with 20's and 10" rim, would affect your braking considering the weight. Also kills gas mileage, if that bothers you, as well as reduced acceleration. I stuck with 19's : 245/40/19 with 8.5 in the front and 255/35/19 in the rear, with 9.5. I also have the eibach pro kit. In my opinion, 19's look a lot better on the coupes and sedans than 20's do.
johnparkyourcar
Car: 03 DG coupe 5AT
any more shots of the car/rims?
TISon28s
TISon28s
Also, I have no spacers.
johnparkyourcar
dam... nice fitment
TISon28s
Thanks John.
johnparkyourcar
Are you on coils or springs? I'd say it could drop a little bit more
Focusedintntions
Car: 07 Infiniti G35 Coupe 6mt
I wouldn't drop it anymore as it looks like he already had rubbing issues on the fronts during aggressive cornering. Look at the last pic just above the top of the tire on the fender you can see damage...
TISon28s
No, just springs. The car is a lot lower thanyou see in the pics. I have no rubbing issues. The fender is from "buffer Burn", from the idiot previous owner who decided to use engine cleaner on chrome wheels to clean them ( my old set)
TISon28s
I also have all fenders rolled, and the rear quarter panel fenders. agrressive driving isnt really a problem. Speed bumps are, my y-pipe tend to hit them often.
johnparkyourcar
Haha my car used to scrape on everything when I had oem 17s. I have the oem 19s now and I'm surprised at how much of a difference it is. I can go over the same bumps I used to scrape on with no problem now.
TISon28s
Oh wow. Im guessing because you're sitting a little bit higher huh?
jentz
hey got 20's anyone have input on removing my front inner fender metal rivets they seem to rub slightly on inclined turns..
Guycomplex
Car: Infiniti G35 Sedan
I like the look of those rims, can you tell me the make and where I could find similar. Also I had questions on the size reading this thread. Like you eluded to, I don't want to mess with gas milage, braking, transmission, rubbing or any of the other stuff you can mess up by going too big. What specs would be good for this car? I don't think I want to lower it as some of the drives I go in and out of already cause me to rub if I don't hit them at the right angle.
Anyway here is a pic of the car.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
