Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Mon Mar 17, 2008 1:40 pm
I had 17x7s on my I30 (4th gen) and they rubbed the plastic wheel well a little.
The issue here is more about the width of the wheels than the height. If you can get some 20x7s then hey, go for it. I'll just be cursing you and wanting to kill you for making a sexy car ugly.
If they are 20x8.5, then you'll probably be having issues. I'd also totally recommend against dropping your 4th gen and running on Dubs. The ride will be beyond unpleasant. My I30 sitting on the Eibach/Illumina setup with 17s and 224/45s was probably at the limit of comfort. Anything stiffer would make your balls ache.
I also just recently came across a 96 Max running Chrome Dubs. One of the sidewalls shredded because of the low profile.
So all in all, you'll be running into problems. I can get you some M35 18s with nearly brand new tires for $600 + shipping, but they'd be around 1/2 an inch taller than stock.
