20" rims need to get calibrated??
All things Altima Coupe.
incREDibL3
Car: Nissan Altima Coupe
Stupidd as$ cop pulled me over merging from another freeway . Saying i was going 86 , i was going traffic flow, i even has to slow down for a mini van to get in front of me, when i just merge into the other freeway. He said that i need to calibrate my rims cause it seems im going faster that what it says in my MPH .. is this true?
I think he was just jelouse that my car was look good. Lol
Should i fight it?
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
If your tire/wheel combo is larger/smaller than the stock diameter, it can cause issues... minor though.. how fast was the speed limit, what did you think you were doing?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
what size tires are you running? you should be on something like 225/40 or 245/35 if you wanna stay close to stock heigh and not have speedo misreads
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
GO here and input your OEM tire size and aftermarket tire size. It will calculate how slow or fast you are running.
incREDibL3
Was going 70-75, just following the trafffic flow. And my tires r 245/35/20...
Blackmobile
that's pretty close to stock, you are going a bit faster though, 3.3%, so when you're going 75mph you're actually doing 77.5, but that shouldn't be enough for a cop to pull you out of traffic. he probably just picked you out since your car is modded and just giving you crap about bigger rims
big_rig
Car: '09 nissan altima coupe 2.5s '88 bmw E30 '93 zj jeep
A cop pulled me over one time because he thought my nose was larger than OEM specs. He suggested i get a gonzo or pinocchio vanity plate to correct this issue.
sickkwidit
Car: 09 Alitma coupe 2.5
i just got pulled over recently too :mad:
