'20 Nissan Versa ticking sound
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
arizonanissan
Car: 2013 Nissan Rogue
Just a quick question-My Versa has 30K today after going through car wash i put my car in park to dry it and noticed a ticking sound under the hood the AC was also on.. The last time i went into the car wash My crash sensors went off from the brushes in the wash--I shut the car off restarted it and crash sensor lights went off--My question is would the ticking sound be coming from one of the sensors or relays connected to those sensors! Maybe they got wet? The enging is always 100% Quiet! Actually sounded like an injector tick or a Lifter noise! Thanks for any help!
Reason: Revise Title
arizonanissan
Just started my car in the garage and what i find is when the AC is off the engine is quiet however when i turn the AC on the injectors get louder!! The noise goes away afet say 5 mins!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
arizonanissan wrote:
Thu Apr 29, 2021 9:07 pm
If it's on cold start then the engine is running "open loop" (all 4 injectors firing together) and the ECM will bump up the engine speed when the compressor runs. That will make the already-loud injectors a bit louder. Once the car warms up and the loop closes, the injectors fire individually and quiet down. Perfectly normal.
arizonanissan
Thank you!
2019Versafan
Car: 2019 Nissan Versa S
Other than this ticking sound, how do you like your 2020 Versa?
arizonanissan
Love it amazing gas mileage runs awesome!
2019Versafan
Sat May 01, 2021 5:19 pm
That's great. I'm glad you like it. My 2019 gets great mileage as well.
Return to “Versa Technical Discussions”
