20 Nissan Versa SV battery size?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
arizonanissan
Car: 2013 Nissan Rogue
Can someone tell me what size battery or type is used for the 2020 Nissan Versa--Is this battery the same as the 2019 battery? Thank you!!
Reason: Revise Title
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
The Fourth generation (N18) Versa's all take the same battery. So a 2019 battery will be the same for the 2020.
PRO TIP - USE THE CORRECT TITLE: That means, make sure your title has the topic at hand. Don't title something: "I have a question" or "Small concern" or "Rogue issues". Instead title it: "Tire tpms question" or "Rear bumper paint issue".
You had two unrelated topics with the exact same title. I've re-titled them so as to avoid any confusion.
arizonanissan
Thank you!!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
They come with a Group 51R, but a Group T4 is actually a better fit. I'm told a Group 47 or 97R will also fit without too much fiddling. The '19's and '20's do take the same batteries, but that's where the similarity ends. The '19's were the last of the "bubble car" econoboxes, the '20's are (forgive me, Nissan) a real car.
arizonanissan
Bought a nice new 35 battery from Costco however i had to make some changes in the battery hold down and the Pos cable almost didnt make it to the pos term! Crazy! But its in now works 100%
VStar650CL
Technical Expert
If you want a hold-down that will look neat and not modified, the gen1 Rogues and gen4 Altimas all took 35C's. The hold-down will have extra holes for an ECM mount but will be the right frame width. Or if you can find one, the holder from a '95~'98 200SX won't have extra holes.
arizonanissan
Ok Thanks so much!
VStar650CL
Technical Expert
You're most welcome. Happy motoring!
arizonanissan
Thank you!
2019Versafan
Car: 2019 Nissan Versa S
VStar650CL wrote:
Fri Apr 30, 2021 3:55 pm
No offense but I happen to love my 2019 bubble car/econobox Versa sedan. I previously had a 2012 bubble car econobox Versa sedan that was very reliable that I loved. The only reason I traded in the 2012 Versa for the 2019 Versa was to beat the $3,000 price increase on the 2020 Versa as I had better places to put that $3,000. My 2019 is just the right daily driver for me. It's not in any way fancy but it does everything I need it to. Just my humble opinion.
VStar650CL
Technical Expert
2019Versafan wrote:
Sat May 01, 2021 4:32 pm
No offense taken. The 6-speeds are a hoot to drive and I wouldn't object to one in my driveway. But they're still an econobox, and IMHO a bubble is a bubble. ;)
2019Versafan
VStar650CL wrote:
Sat May 01, 2021 4:49 pm
So glad no offense taken. An econobox was exactly what I was looking for that was still at an affordable price. Now even the econoboxes are close to $20,000 before tax and registration which is way more than I wanted to spend. I've learned to ignore the bubble styling and how to work around the CVT. I'm very glad to have my 2019 Versa in my driveway because it makes it possible for me to have more money to spend on my pampered show car. That's a win win for me.
Return to “Versa Technical Discussions”
