auditech10 wrote:All cars come with a 5 bolt pattern, dont they.
Some smaller/older cars use 4 bolt patterns. My 1985 300ZX Turbo had a 4 bolt pattern.
auditech10 wrote:Also, the M, G35cpe and 350z all share the same bolt pattern with every other Japanese car, 5x114.3
Too general a statement ... I think! As I recall, some Honda models have a different size pattern.
More importantly, the hub bore can be quite different. For example, Lexus wheels will NOT fit on Nissan/Infiniti cars. If the hub bore is too small, you would need to ream it out (dangerous) and if too large, then you would need to use a centering ring or let the bolt/buts center the wheel (too much sideways pressure on them then.
1. The best thing to do is to use the OEM wheel the car came with. Spend your hard-earned money getting the best tires you can.
2. Next best thing is to use an OEM Infiniti wheel from another Infiniti model (with correct width and offset) and get the best tires you can.
3. Final thing is to buy a properly fitting wheel, designed for the specific sizes for your car, from a good reputable wheel manufacturer and get the best tires you can.
4. Anything else cannot be recommended.
P.S. Splurging on expensive after-market wheels (or even other Infiniti wheels) and then fitting crappy tires on them is the stupidest thing anyone can do ... sacrificing performance and handling for looks is silly.
Z
