20 degree water pump question
renekko01
Car: 01 Infiniti I30
I was doing so research on how to replace water pump on you tube and fsm. The only real concern or question I have is it says to turn the crankshaft 20 degrees counter clockwise to loosen the timing belt. What is the simpliest way to know what is a 20 degree turn of the wrench. Is has to be exact I assume.
Here's a pic of a degree wheel. http://www.texample.net/tikz/examples/degree-wheel/
30 degrees counterclockwise would be 11:00, so 11:15 (roughly) if you imagine a clock face.
It's going to be a rough estimation, but the real issue is simply rotating enough to create slack in the belt.
renekko01
Thank you very much it means alot to know people are like minded when it comes to being stand up and informative. Not everyone appreciates advice, and any advice is better then no response soa huge thank you sir.
That's what we do here. Always have, for 17 years. Welcome aboard.
