20 bucks got me....
GhostDriver
Car: 1991 Nissan 240SX RMS13
... two racing harness'. I got them from a friend who was selling his FC for 20 cash dollars. Booyah!They say mazdaspeed but it doesn't look authentic, maybe an ebay knockoff. I don't really care as long as they do the job. CAn anyone verify that I hooked it up right. I just used teh existing wholes. I think AxelGrungy has his like this as well. Take a gander.
As for my seat here it is in all it's uh grandeur(?)....behold.
And lastly, yes Rico it is FIA approved.
Ok mang tenk you.
hannibal
Car: Red Line to Glenmont
Looks good. I think as long as the belts are bolted down, it should be OK. Make sure the head of that nut is much bigger than the hole (maybe use a large washer??)
See, S13 seats arent that bad. I couldnt use those belts on my S14...
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
http://cgi.ebay.com/ebaymotors...ZWD9VYou saved exactly $7.87 by buying used harnesses.
Axel Grungy
Car: 2001 G20 5spd
i hooked up my rear points to where the rear seat retractor is up on the pillar. but your way will work also.
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
20 bucks got me 1/2 tank of gas. your deal was much better.
GhostDriver
Damn....lol. I should have offered 10 effin bucks.LOL Oh well, now I need gas money.
swwifty
you need either a roll cage, or a harness bar. Hooking them up that way will get your seriously injured in a accident. Also, I'd consider some certified harnesses, so the cheap ones don't break if you get into a accident.
starscream6
Car: 93 civic/B18c
your gonna get hurt with that set up. seriously
GhostDriver
They're only for track use...I don't use it on the street. I need longer bolts and some washers.
swwifty
all the more reason to have a proper setup.
are you refering to drag racing, or a road course?
TOPSECRT88
Car: S14
Dont mean to steal your thread man..........
But what is the proper set-up?? I have just bought some Sparco 4pt's for my BuddyClub seats in my S14. What would be the safest way of install short of buying a cage?
Modified by BuddyClub240 at 10:06 PM 8/18/2005
GhostDriver
My car is too slow for drag racing so I'm sticking to the road course and autox. I know what you mean though. SHould I get a plate behind the bolt (under the car) to reinforce it?Thanks for the input....keep it coming.
MysteryIncMan
Car: 1995 240sx SE
Man 20 bucks got me a set of s14 Kouki Tails.
97ka-t
1998 Nissan Altima
MysteryIncMan wrote:Man 20 bucks got me a set of s14 Kouki Tails.
drftsil8ty
Car: Cobalt SS turbo
wish i can find deals like you guys!
DRIFTEADOR
a proper setup would be one that angles the belt 90 degrees from the body. c pillar bar would work. the setup pictured above will crush your collar bone in a frontal crash by pushing down on it.
nismo521
Car: 1993 Nissan 240SX HB
BuddyClub240 wrote:Dont mean to steal your thread man..........
According to Simpson, the attachment point of the belts when the user is seated upright should be no more than 10 degrees below the shoulder. Having them mounted to the floor like that will cause spinal compression, even in a very minor impact. Probably the safest way to put them in without buying a cage would be to have a harness bar mounted as close to the back of your seat as possible that will allow the belts to be either level with your shoulders or no more than 10 degrees below.
swwifty
if I were you guys I'd get harness bar (cheapest). That will allow the harnesses to run at the correct angle without any possibilities of injuring yourself.
TOPSECRT88
Car: S14
swwifty wrote:if I were you guys I'd get harness bar (cheapest). That will allow the harnesses to run at the correct angle without any possibilities of injuring yourself.
To my knowledge I dont think they make a harness bar for 240's. I checked with Sparco and they said they will be releasing one late this year. Do any other companies make them??
cheez80
Car: percussion =D
if you take a look at sparco's catalog, they say a mounting point such as ghostdriver's is ok. they also list degree measurements along with a snazzy diagram, but i forget what those measurements were.
GhostDriver
OK....now that I slept on it. I'm going to ditch these and get a real harness as well. I just got them because I thought it was a smokin' deal.I just realized that I pulled a 'jack 'n the beanstalk' move by getting these instead of gas.lol
sensibleS13driver
i got a real Sabelt 4 pt for $20
swwifty
I looked at Sparco as well, I think you could probably get one custom made for pretty cheap.
240sxjeff
Car: nissan 240sx zenki version
Hi guys, I had a quick question abou the harness bar, where exactly does this bar go?I was wandering through ebay the other day and saw a bar that connected the top of the rear seat belt mount. would it be safe to mount the harness to that or is it too far back?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
I'm sorry for doing this and I am surprised that no one has said anything but why are you sporting "Mazda Speed" harnesses on your S13???
Mixmastamunkh
Car: nissan 240sx
thank god you said that, because i was just about to post it. yeah, that is just as ridiculous as people sporting "VTEC" stickers on s13's. ditch the mazdaspeed harnesses. it's really tacky.
MAXIMUS Nismo
Car: 95 240sx SE
I may be wrong, but your hookup locations are dangerously incorrect. In an accident, the harness (because of it attachment location, the floor) will pull you downwards, and may compact your spine. Not a pretty thing.
I think that the correct way is to have them attached to a harness bar. A horizontal bar that attaches to your the left and right sides behind your seats. Lemme find a pic.
BRB
MAXIMUS Nismo
Car: 95 240sx SE
ok, here's one that I found.
So in an accident, you'll be pulled back into the seat, instead of down to the floor. No more spine injury.
Can someone else please verify if I'm right, or if I'm way off.
swwifty
that is correct.
halfassracing
Car: 1993 nissan 240sx
u want to get rid of those belts?
