2 way lsd question
A home for 1983–1989 300ZX owners!
kusakari_boy
i was reading on some other forums that cusco s13 mz 2.0 lsd could work on z31 i was wondering if any did it or could just help me understand swapping lsd
thanx
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
cusco as well as many other manufacturers, makes an R200 LSD, which fits in your Z31
late S30's, S130, Z31, all use the long snout R200, the S13, S14, and Z32 N/A all use short snout R200, the carrier is interchangable, the gears however are limited to their intended style housing, the R200 is also found in some trucks, older RWD's as well as some infiniti models, when you buy a new LSD you only get the carrier you have to use your gears and housing, and the 87.5-89 z31's came stock wth a clutch type LSD with a 3.7:1 if you manage to find a donor
winez31
Car: 1993 s13 ka24de
i think the s12 silvia uses a short nose, but im not positive. i do know it uses a r200 diff tho.
evildky
06 Nissan 350Z GT
the 200sx (rwd) used the long snout R200, I believe thats an S12 chassis?
winez31
yeah your right thats why i said i wasnt positive
kusakari_boy
thanks for the info
after i read some more im thinking about the r200 clutch type lsd from nismo
Return to “300ZX (Z31) Forum”
