ok so if i do put it in will it have to be done by a shop or will i be able to put it in there myself?the converted wrote: Put it in and see how you like it, I think you'll be very happy with it.
FYI, it's the driver, not the diff.SullivanRacing06 wrote:i just blew my vlsd on dyno todaym threw in a welded diff, sucks balls! ran from these things called the fuzz in my neighborhood and my pass front side had a nice lil run in with a curb, nothing to bad but holy $hit, thought i messed up allot more then just a 200$ rim lol, go witha 1.5 or 2 way kaaz, im waiting for mine to come in along with my nismo power brace and tention arms
thanks guys for all the help.Okay so i am looking forward to changing it my self, i did a rebuild on my motor and never did any other motors and it runs fine, so i think i can accomplish this one. just not to sure what you are talking about when saying checking/setting gear lash. i will have a buddy or two with me to check things up, but they never did this either.ashoe wrote:You can change it yourself. The process is in one of the write-ups, but if you aren't familiar with checking/setting gear lash it may be better to have a shop do it. It's about a 3 hour project if you chose to do it yourself.
They are talking about the amount of play between your ring gear (big one) and your pinion gear (small one). It's called backlash.lilpiton wrote:
yea thats whet i was gonna do, take out the pumpkin and give it to em. Thay told me $470 to get it installed!ashoe wrote:A shop probably won't charge much if you take the diff off your car and bring it to them. Just something to think about
It is true, you can go by the, "I hope" method, but it's still a gamble.I've known people who have destroyed differentials because of that.ashoe wrote:A lot of people just use the shims that were in the case with their original diff and turn out fine. It is one of those things that should be done right but... will probably be ok if you don't
Could probably get it installed for less. A shop probably won't charge much if you take the diff off your car and bring it to them. Just something to think about
Doesn't sound too bad. If the shop charges per hour, lets say it takes them an hour to take the diff out, an hour to work on it and, an hour to set backlash and what not.ashoe wrote:You don't need the axles. it will bolt right up to the ones on there. 470 is totally outragous. once the pumpkin is out of the car the job takes like an hour or less. Find another shop. No need for performance shops for this job. Any competent transmisson shop can do this.
Thats what im gonna have to do then.thaks alot guys...ashoe wrote: Find another shop. No need for performance shops for this job. Any competent transmisson shop can do this.
