deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sat Mar 25, 2006 2:03 pm
The tps connector that is built into the actual tps unit (one that comes straight out the front) is the tps idle/wot switch.
On a 5 spd, only the the idle switch is used, both the idle/wot are used on the auto. So on this connector if your car is 5spd harness you will have 2 wires, if it is auto you will have 3.
The connector that hangs off of the tps with the 3 wires is the actual TPS potentiometer and is definately required.
You need that second connection hooked up, your harness should have the connector for it, all nissan harnesses have them. It should be about 3-4 inches down from the other tps connector, wire colors may be white, black, and light green with red stripe.
On the actual tps connector the wires are red, white, and black, they change when going through connector.
That might not be clear, feel free to ask.
