rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Tue Oct 23, 2007 4:55 pm
Well, problem solved....
I hooked a hose to the fuel filter line and turned the car on and watched the fuel pump pour the gas out into the gas can, then ran it through with a gallon of 93, then hooked it up and had to crank the starter for about 10 minutes before it would even stumble.
I took out the plugs, which were covered in oil, cleaned them, sprayed carb cleaner into the plug holes and cranked it to spray it all out the top, then put the plugs in and she purred like a kitten. Ran a bit rough and smoked a few miles then was nearly perfect.
New plugs and fuel filter with Lucas fuel injection cleaner concentrate on 10 gallons of boosted 93 octane later and it makes more power than before. Nice and smooth.
Clean sailing... <---- Got my hater blocka's on!
