2-speed transmission? Q45 not shifting.
HSN
Car: 92 Q45
Well, within two days of owning my Q it's sparked a remarkable amount of problems for how easy I've been on it. The main one I'm concerned about is the transmission will not shift above second gear. In "1," it stays in first gear. In "2," it stays in second gear. In "3" and "D," it will stay in second until about 3000 RPM, sometimes it will simply stay in second, no matter how high it is revved up it will not shift, sometimes it will rev up freely (as if in neutral) until it hits 5-6000 RPM, then it will shift down to first gear. Not what I'd call healthy at 50 miles per hour. Unless I'm mistaken, it's not even supposed to be in first gear in drive. It did not have this problem when I test drove it but now it always happens. A problem I think might be related is the "TCS OFF" and "SLIP" lights are always lit up on my dashboard, and it will not let me turn the traction control on. Also did not happen during test drive.
Any ideas? Thanks in advance.
-Matt
qship96
Car: 1996 Infiniti Q45
throttle position sensorworn out transmissionhopefully the first,as it is much cheaperwhat year q,and how many miles are on it?pull trans dipstick and check fluid level,and color on a white paper towel,and report back!
pretzelboy
This post makes me feel better
PoorManQ45
Maybe you are the luckiest SOB and you bought a Q45 with a level ten transmission with a high stall speed torque convertor!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
HSN wrote:1.) Well, within two days of owning my Q it's sparked a remarkable amount of problems for how easy I've been on it.
2.) ...sometimes it will rev up freely (as if in neutral) until it hits 5-6000 RPM, then it will shift down to first gear.
1.) How hard can you flog it in two days?
2.) Can you say toast?
Hard to give a good analysis without a complete service history and detailed description of fluid, circumstances under which fault occurs, etc.
I think you need to read the posts about transmission replacement. Sorry.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Why not search and find the diagnostic procedure for the transmission. What year? What does the fluid look like/low? Is the filter clogged/exchanger clogged? How can anyone even help without the most basic of info?
HSN
Car: 92 Q45
It's a 1992 Q with about 80k on the motor/transmission. Haven't checked the filter, I checked the fluid this morning and it looks brownish-purple, going to change that and see what happens then report back.
-Matt
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
HSN wrote:I checked the fluid this morning and it looks brownish-purple, going to change that and see what happens then report back.
Not good, but not necessarily fatal. Search the board for flushes. Think the nearest BG machine is out near Tigard. Call first.
DougQ45
Car: Q45, porsche 928 S 5 speed
Don't just change it----flush it! If your radiator located heat exchanger is plugged (probably) then fluid will not circulate properly. If so, read up on posts about installing a transmission cooler. After you have proper fluid circulation, and have exchanged the fluid, do a pan drop (checking for debris etc... on the magnet) and filter change.
