2 Seater Rotors On 2+2
islandtuner242
Car: 1990 Nissan 300zx N/A 2+2 SOLD!!!
2003 Infiniti G35
ok i found a 2 seater N/A shell not to far from me and i was wondering if i can use the rotors off it (seeing as how they are drilled & slotted) or is there a difference between the body styles
Anti-HondaZX
Car: 1990 300zx NA Coupe 5 speed
islandtuner242 wrote:ok i found a 2 seater N/A shell not to far from me and i was wondering if i can use the rotors off it (seeing as how they are drilled & slotted) or is there a difference between the body styles
yes sir they fit... unless of course either your car is a 90 and the other car is not a 90 because the front rotors are a different size on the 90 ... but any other year is fine
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
All suspension/ braking components are the same other than previously mentioned brakes. Also, same engine, same transmission, same differential. Everything else, you can pretty much assume is different.
islandtuner242
2003 Infiniti G35
thanks guys
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Careful, while this is true within years, 90 vs 91, 91+ is different. If it's a 90 NA you found, you are good to go. If it's 91 or any year TT, the rotor thickness is different (30mm vs 28mm). Either way I would get the brakes, if it's a 91, then get the calipers and brackets as well...
